Thread: Help with testing water
    Mar 2012
    Kansas City, MO
    59
    Here's our results
    FC 2
    CC 2.5
    TC 4.5
    pH 8.2
    CH 250
    CYA, here's where I'm having trouble. I've got the tf100 and i guess I'm not understanding the test completely. We've done it twice and still don't understand the whole "black dot" thing. Can anyone explain it to a layman?
    15k gallon IG kidney pool with attached spa
    plaster
    sand filter
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Help with testing water
    Try the Extended Test Kit Directions. Also, the article contains a link to Taylor Technologies that has a pic or two of the process. Post back if you have q's.
    extended-test-kit-directions-t25081.html
    You're done SLAMing when:
    Mar 2012
    Kansas City, MO
    59
    Thanks. Guess we did it right, we just have 0 CYA.
    plaster
    sand filter
