Thread: Solar Roller
    Solar Roller
    Any one use this or seen it in action?
    http://solarfactory.com/
    I was looking at it as an option for the solar cover due to space limitations.
    18x36 29K gal Gunite - 1 HP Hayward Super Pump
    Hayward Aqua Rite - 40k Cell - 24" Hayward Pro Sand Filter
    Polaris 380 w/ booster - RayPak 336K BTU Propane Heater
    Twitter: @jfgreco
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Solar Roller
    I used one for a number of years but the salt (SWG) corroded the aluminum pipe in a few years. It worked pretty well and if if you don't have high salt, it would probably last longer than mine did. I still use a variant of the design and replaced the aluminum pipe with 1 1/2" ABS pipe (floats), but still using some of their hardware for the cover attachment.
    Mark
