Thread: New here
    New here
    Hi, new here just put up our first pool a Summer escape pro series 16 x 48? Fist thing I see is that the pump seems under powered did some reading and seen that some have replaced with a sand filter and more powerful pump . My question is Is this pool worth spending the time and money on the pump upgrade I don't mine doing it if the pool will last
    Re: New here
    Welcome to TFP!
    What size/kind of pump and filter do you have right now? Some of the smaller above ground pools do come with a pump/filter that is too small, but it is also very common for people to mistakenly think that bigger is better right up into the way too big range.
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    573
    Re: New here
    Welcome! Soft side pools can last many many years if taken care of properly. The Intex pumps and sand filter systems are a pretty good bang for the money on most Intex size pools. Definately worth a look.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: New here
    Welcome to tfp, Elob9
    I agree that intex makes decent sand filter/pump combos. You could also look on craigslist.
    Re: New here
    The pool is suppose to have a 1000 gph pump which mounts on the bottom of the skimmer. I really doubt it can move that much water with the vacuum attached it has very little suction
