Thread: Ph question
    Ph question
    I test Ph every night and the last 2 nights it has been 7.8. Should I go ahead and lower it or leave it alone until or if it gets higher?
    Intex 18 x 48 Ultra Frame, 1500 gph Intex Krystal Clean filter pump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Ph question
    I'd go ahead and push it down. 7.8 may be the top of your test so you can't be sure where you are.
    Re: Ph question
    Thanks so much, I will go ahead and lower it.
    Side note, I'm from SW Indiana too.
