Results 1 to 7 of 7
Thread: Jack's "After Shock" Product
    Aug 2007
    Austin, TX
    343
    Saw this on the shelf at the local pool store. Thought it was an interesting idea. Any thoughts on it? Will it introduce bad chems to a BBB pool?
    20k Gunite/Prism Blue-Pebblesheen, Pentair Tagelus TA-100D Sand Filter, Heliocol Solar Water Heater, 2 bubblers and 2 waterfalls installed 2007, 3hp IntelliFlo VS Pump 011018 installed 2013, Aquabot Turbo T4 RC and Stenner 45MHP10 w/The Liquidator container installed 2012.
    Antigua Spa by Artesian Spas: 325 gl, 52 jets, 6 hp 2 sp & 6 hp 1 sp, Circulation System 24 Hour Whisper Pure, Ozonator, LED digital lighting, The Artesian Pillowfall installed 2007.
    Retired: 2hp Pentair Whisperflow, Legend Platinum w/booster pump, PH Adjuster
    That is a great product, but there are very few situations where you actually need it with an outdoor pool. Chlorine levels will come down on their own and in most cases having higher chlorine levels is not a problem. Jack's sells it because of very specific situations where you need to go rapidly from high chlorine levels to low chlorine levels as part of removing specific kinds of stains.
    Aug 2007
    Austin, TX
    343
    Oh.. I thought it might be a product geared towards getting you back in the water sooner by reducing the chlorine levels quicker.
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    stuffs pretty expensive too if I remember right
    Brian
    20K IG Gunite w/ raised 7ft spillover spa. 1.5 HP Hayward Northstar pump 425 sq ft Hayward cartridge filter, Colorlogic lights AquaRite SWG AquaLogic PS-8 control
    1hp pump for sheer descent
    Guest
    Chlorine killers are made my several companies and most pools NEVER need to use them.
    They are for very special situations, as JasonLion pointed out.
    I have found a chlorine killer to be a decent adjunct to my spa, as the chemicals in the spa are much more difficult to control exactly. For the spa, it is cheap to use occasionally. For me, the cost to lower the chlorine level in my pool is much higher than the cost of my yelling at the kids to stay out of the pool until tomorrow.
    19,000 vinyl pool, solar heat, .75 hp tristar, 48 sq ft de filter
    Guest
    Be aware that most of them will add sulfates and/or sulfites to your water.
