Results 1 to 7 of 7
Thread: Pressure Gauge?
    StevethePirate's Avatar
    May 2012
    West Georgia
    4
    Pressure Gauge?
    First off, I Love the site. A lot of fantastic info and I've learned quite a bit on what I may be doing wrong. I'm definitely going to get on the BBB method next season.
    Anyway, I'm wondering if you use a well pump pressure gauge for a pool pump? The reason I ask is that I've purchased one two different times to replace my current gauge that isn't getting a reading. I took the first replacement back b/c I thought it was defective, but the second isn't getting a reading either. So I'm wondering if it is the gauge type, or is there something in my lines that would prevent the gauge from getting a reading. The flow is strong and everything seems to be pumping fine.
    16' X 32' 8 ft deep end 21K Gallons?
    Jacuzzi Sand Filter
    IG
    1.5 HP Jacuzzi Pump
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Pressure Gauge?
    Pool company branded gauges are notoriously bad, a well pump gauge should work, in general any gauge in the right pressure range rated WAG (water, air, gas) will work.
    38,371
    Re: Pressure Gauge?
    Have to ask ... why wait until next season to start?
    The BBB method is really just about understanding your water chemistry and only adding chemicals that your pool NEEDS, thus saving money over what a pool store wants to sell you.
    You can be on the BBB method and use any form of sanitation you want ... you just have to understand what you are adding and why.
    May 2012
    West Georgia
    4
    Re: Pressure Gauge?
    Well my CYA is sky high as in my Taylor kit only goes to 100 ppm and my water level in the test tube is a quarter inch below that, so I would have to replace at least 60% of my water. My pool only gets partial sun so it would be a few weeks before my water temp gets back to 80+, which is the minimum for my wife to get in. Plus I've already got around 50# of granular shock since I stocked up before I found this site.
    I got bad advice when I bought my house, the guy just told me to brush and vacuum once a week and use granular shock, 2#s a week and if you see algae start to creep up, shock it, brush and run the pump until you don't see it anymore. I'll admit, I've never really had and clarity problems using this method, but I'm constantly fighting light algae blooms and I go through about 100#s of shock a season.
    Jacuzzi Sand Filter
    IG
    1.5 HP Jacuzzi Pump
    May 2012
    West Georgia
    4
    Re: Pressure Gauge?
    Quote Originally Posted by Isaac-1
    Thanks for the reply. Why do you think 2 well pump gauges aren't giving a reading then? Maybe a bad batch from home depot? Is there something that could be happening that lets the water flow fine, but not give a pressure reading?
    Jacuzzi Sand Filter
    IG
    1.5 HP Jacuzzi Pump
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Pressure Gauge?
    It seems unlikely that the port to your gauge would be blocked. This is probably a bad idea but if you take off the gauge turn on the pump and water shoots out then your gauge is bad.
    May 2012
    West Georgia
    4
    Re: Pressure Gauge?
    Thanks for the help ya'll. Turns out I was tightening the new gauge too much, if I would have read the label on the pump that said " hand tighten plus 1/4 turn" I could have saved us all some time...
    Jacuzzi Sand Filter
    IG
    1.5 HP Jacuzzi Pump
