Results 1 to 15 of 15
Thread: Sharing my pool
    moze229's Avatar
    Jul 2011
    Central NC
    108
    Sharing my pool
    I just wanted to throw a quick pic up of the pool this season so far. Here's where I was last year just after install. This is the grade I had to deal with.
    [center:2pow04n7]
    [/center:2pow04n7]
    [center:2pow04n7]This is where we are now.
    [/center:2pow04n7]
    We managed to get things to work out ok. I decided to have the deck built to the same level as the top rails. It works better for us because it allows you to sit comfortably at the pool edge and hang your feet in. We had some board shrinking as expected over the winter, but I'm not going to worry about it. If it starts to bother me too much, I'll just replace the boards that shrunk more than the others. I have a stock pile of decking boards out in the wood shop. As you can also see, we live out in the middle of the woods so I think I'm going to have to take more trees out. We only get direct sunlight on the pool from about 12:00PM to 3:00PM and as a result, our water is still at 75 degrees. I need it to be about 5 degrees warmer. I think once we get into June and July we should get there.
    I wanted to thank those of you for your input, suggestions and knowledge along the way. This is a first pool for me, and we've been enjoying it so far. I'll be putting up some other pictures of the complete setup soon.
    24' X 54" Sharkline Matrix AGP ~ 15,200 gallon
    1.5 HP Dynamo Dual Speed ran 24/7 at low speed w/250lb. SD60 Pentair Sand Filter
    Plumbed with PVC - buried.
    Re: Sharing my pool
    Wow, I thought I had it bad with my grade! Nice pool, I hope the leaves don't drive you crazy with the constant cleaning.
    Crazykidsdad
    My Crew: Keith, Connor, and Alex
    AG Summer Escapes 36x12'
    3400 (Approx)
    Generic Pump / Filter
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: Sharing my pool
    It looks amazing! Very nice. You've been a busy bee haven't you?
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: Sharing my pool
    Quote Originally Posted by crazykidsdad
    The skimmer should catch most leaves. Problem is, when the pump is off, no skimming. As long as the skimmer functions before the leaves become waterlogged and sink they shouldn't be an issue though.
    38,299
    Re: Sharing my pool
    Looks really nice ... especially the trimming of the boards around the pool.
    Any concern over the wall of dirt around the pool being eroded by rain and washing down against the pool? Seems like a wall or something would be a good idea ... unless this pool is designed for partial burial where you could actually back-fill up against it.
    Jules's Avatar
    Jun 2011
    Kemp, Tx
    111
    Re: Sharing my pool
    It looks great!
    -Julie
    25,600gal/33' x 52" Sharkline Heritage, Pentair Clean & Clear 150sq ft filter, 1.5hp dual speed Optiflo pump, TF-100 test kit, BBB method, Pool Rover S2-40
    moze229's Avatar
    Jul 2011
    Central NC
    108
    Re: Sharing my pool
    Thanks for the comments all! I'll be including some additional pictures soon that will explain the grade issue. We built a block retaining wall behind the pool, which isn't visible from this picture. I far as the front end - I just buried it. It's about 50% buried in the front. I'm taking the risk against corrosion and this is my reasoning. If the bottom 3-4" of the pool can be covered like it usually is, why not 20%? Or even 50%? As far as corrosion is concerned, it's the same material at the bottom portion of the wall as it is at the top. So if corrosion is an issue, it's not just because it's buried. Now as far as caving in - that's a risk that I'm taking. I'm just betting that when I have to replace the liner, I can do it quickly enough to not worry about the wall collapsing. The soil here is 90% clay anyway, so once it's formed and packed it's not usually going anywhere anyway.
    The leaves were troublesome last year but I closed the pool late. I'm going to be closing a little earlier this year.
    30,421
    Re: Sharing my pool
    I don't think I have ever seen a better looking deck/pool fit like that. Kudos for thinking it through so well. Did you build it yourself? The workmanship is excellent!
    67ragtop's Avatar
    Mar 2012
    Tampa, FLA
    12
    Re: Sharing my pool
    Beautiful install and deck!........hope ours turns out as well. Do you have solar to deal with the temp issue?
    33" Oxford Aluminum AGP, Hayward Aqua-Rite SWG with T-15 cell, Clearwater 150 Sq. Ft. cartridge filter with 2-speed 1.5 hp pump
    moze229's Avatar
    Jul 2011
    Central NC
    108
    Re: Sharing my pool
    Thanks duraleigh. I did not build the deck myself, but I did add some things afterwords. I built the gate and added the skirt around the bottom. I had a guy that's done some work for us before do the main build. I just told him exactly what I wanted to do, how I wanted the decking boards, etc. and he just did it. I was going to take it on myself, and I was sure that I could have. But, it would have taken way too much time for me to do. We just bit the bullet and paid for the build. And believe me - we paid for it.
    Quote Originally Posted by 67ragtop
    I haven't messed with any type of temperature control yet. I want to run through one entire season to see what happens first. As I stated, for a mostly shaded pool we are at 75 degrees so far. I'd like it a little warmer, but we have a lot of swim weather to go still.
    I wanted to go ahead and put the rest of the pics up here so that I can answer any questions, defend myself, get reamed, whatever might happen.
    [center:jlppuo89]This is a shot of the grade after landscaping.
    A closer one from one side.
    The retaining wall in the back.
    This is the opposite side with the stairs.
    Deck view.
    A view from the other side of the deck.
    Access panel for the skimmer. No, I do not have direct access to the return but I can reach it from this access point. Or I could crawl under the deck. Or, I could just remove a board if needed. The decking support around the skimmer is screwed together rather than nailed so that if I ever need to remove the skimmer, I can.
    Pump and filter. I know, I know. I plan on hard plumbing the connection soon, but last year I didn't have a lot of time and just wanted to get everything going.
    [/center:jlppuo89]
    For plumbing, everything goes underground and up to the pool. It's about a 1 ft. incline to the pool, but the Dynamo handles it no problem.
    Well, that's it. I just wanted to share because I've gotten a lot of help here.
    Re: Sharing my pool
    Very nice! We got the same pool installed this year to replace a 12 year old pool (same size) that had corroded. I love how you did the deck even with the top rails.
    You might want to consider putting a solar blanket on at night. It really does keep the heat in overnight, and that nice big deck could accommodate a reel easily.
    For the leaves, you may want to look into the PoolSkim... we have one and it does great.
    Sue
    Current Pool: IG Concrete / 11,000 gal. / Sand filter / Solar heat / Hayward CL200 / Screened / TF Testkit
    Pool owner since 2001. Thanks TFP for helping me convert off Baquacil after six years!
    nelson411's Avatar
    Aug 2011
    Northern California
    165
    Re: Sharing my pool
    What a beautiful set up! That deck is incredible!!
    That's what we want, but we will have to wait! I think the Matrix is a great pool!
    May you enjoy years of happy times with your beautiful pool!!
    Cheers,
    Liz
    Northern California Inground pool 14' by 30'
    Diamond Brite Quartz Medium Grey Plaster - Islands Sapphire Breeze Tile Border
    Jules Bright Cobalt Blue Blend Tile Bench fountain sheer waterfall descent
    Pentair Intelliflo Variable Speed Pump - Pentair CLean & CLear PLus Cartridge Filter - Kreepy Krauly Legend - mTF-100 Test Kit - Swimmers: Twins (Boy/Girl) 16 yrs old
    Hub's Avatar
    May 2012
    DFW, TX
    19
    Re: Sharing my pool
    Beautiful. Well done.
    1200 gallon, 10'x30" Intex AG metal frame
    Type A cartridge filter, 1000 gph pump, wall mounted skimmer.
    moze229's Avatar
    Jul 2011
    Central NC
    108
    Re: Sharing my pool
    Quote Originally Posted by MeSue
    Thanks for the comments. I'm looking at solar blankets now so I've got a lot to figure out on that still. Thanks for the suggestion. I also did a search for the PoolSkim - nifty little device! If I were to extend our swim season somehow I might try and take advantage of it but I don't think I'll have the pool open long enough to really get use out of it. We'll see what happens this year.
    Quote Originally Posted by nelson411
    Cheers,
    Liz
    Thanks Liz!
    Quote Originally Posted by Hub
    Thanks!
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Sharing my pool
    Wow, what a nice job! Everything looks fabulous including that sparkly water!
    I agree with you....those dang trees! Too many! Some gotta go!
    You're done SLAMing when:
