Results 1 to 12 of 12
Thread: Season 2 on BBB
    Season 2 on BBB
    Hello this is my second season on the BBB method and so far so good.
    Im not sure if this should take longer or not but just like last year it is taking awhile it seems like to clear my pool of algae. I believe the problem is with my filter, i have been keeping my pool at shock level for 5 days now and in the past 2-3 days the FC level has not really gotten farther then 3 below shock level of 12 for my pool, and today it didn't move at all over night. So i think my filter has trouble filtering out the dead algae. I had this same problem last year. I feel like there is a problem with my system, i wish i could try someone else's pool for a year just to see how it should go or maybe its just me...
    Here is the test for this morning:
    FC: 14
    CC: > 0.5
    Here are pictures from day 4 and today day 5:
    5/31/12
    6/1/12
    16'x32' / 21,000 Gal / In Ground / Vinyl
    Hayward Sand Filter S220T / Hayward-Magnetek 1/2 HP Pump
    Nitro Wall Climber Robotic Pool Cleaner
    BBB
    TF-100 Test Kit
    Feb 2012
    Phoenix, AZ
    728
    Re: Season 2 on BBB
    I can assume you are running your pump 24/7, correct? How is the pressure? And how often are you backwashing? Stick with it and you will have a trouble free pool soon!
    Aug 2010
    Dallas, TX
    4,052
    Re: Season 2 on BBB
    2 weeks is not uncommon.
    Re: Season 2 on BBB
    Quote Originally Posted by blakej
    Yes pump has not been turned off at all
    When clean pressure is 11 psi ... not sure if thats good or bad or does it vary by system...?
    I try to backwash at least once a day...
    Current measurements:
    FC: 11
    CC: 1
    Would adding clarifier or DE speed up the process or make it more complicated ?
    Thanks
    BBB
    TF-100 Test Kit
    Re: Season 2 on BBB
    @RobbieH
    Do you have pictures of your pool posted somewhere? by your sig looks like its a must see!
    BBB
    TF-100 Test Kit
    38,548
    Re: Season 2 on BBB
    1. Keep the FC ABOVE 12ppm at all times ... shoot a little high if you will be away.
    2. Backwash your filter when it goes up 20-25% of your clean pressure. For you, before 14psi
    3. Keep the faith
    Given that the pool is still green and not cloudy/blue ... there is still algae living. How certain are you of your CYA level?
    Re: Season 2 on BBB
    Ya i just added some more chlorine
    i will keep an eye out on the pressure
    I've tested it a couple times before and it looked to be around 30... i still have not understood if the test means once it gets hazy or once you can not see the dot at all... cuz if its just a little haze then mine is higher then that.. Also if i test now will it be accurate anyways from high FC ?
    thanks
    BBB
    TF-100 Test Kit
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Season 2 on BBB
    Quote Originally Posted by gorgio1
    thanks
    The moment the dot disappears (as in, like you didn't know it was there in the first place), the test is done. Sounds like your CYA is higher, which means you need to hold a higher shock level.
    Re: Season 2 on BBB
    Current Readings Day 6:
    FC: 9
    CC: 0
    ph: 7.5
    CYA: 45 - 30 ? Look Below V...
    Here is how i did my CYA test... Let me know which level i should choose:
    Here was around 50 -60:
    40:
    30:
    20:
    What i would have said before would have been about 30 CYA correct me if i am wrong...?
    Here is my ph test just for fun... 7.5 right?:
    And here is the current condition of my pool... it does seem to be getting better:
    Thanks everyone!
    BBB
    TF-100 Test Kit
    Re: Season 2 on BBB
    Your CYA is around 20. I can see the black dot at 30. The black dot should be completely gone, as if it was never there, even if you stare at it for several seconds.
    Re: Season 2 on BBB
    Slowly but surely! #BBB
    Thanks everyone for all your efforts!
    BBB
    TF-100 Test Kit
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Season 2 on BBB
    Your CYA tube was in direct sunlight and that will tend to under-estimate the CYA reading so I'm guessing more like 30-40 instead of 20 where Jason is correct if one just looks at the pictures. You should hold the tube in front of you with your back to the sun so that you are shading the tube. You want strong indirect sunlight, not direct sunlight.
