Thread: Shocked last night....FC fine....big PH increase
    Sep 2007
    Gloucester County, NJ
    141
    Before shocking the pool with 12.5% liquid chlorine, I had the following numbers:
    FC .5
    CC 1
    PH 7.2
    TA 70
    CH 210
    CYA 40
    I put in enough chlorine to take the FC level to 15, based on Jason's Poolcalculator. This morning, my levels are:
    FC 15
    CC 0
    PH 8 <<-- This is where my question lies
    TA 70
    CH 210
    CYA 40
    So, as you see, the FC level appears to have held overnight, which I wasn't expecting. However, my PH level shot through the roof. I had put in muriatic acid to bring down the PH as the PH was really high when I opened the pool. I expected it to drift upward, but between yesterday evening and this morning it increased dramatically. I don't want to just add more acid as I know that will also reduce my TA. I also don't want to just add baking soda to raise the TA as that will also raise the PH. What's the best approach here?
    28,000 gallon gunite/white plaster with 30ft RBB and 2ft sheer descent, 100 sq ft thermaledge, 50sq ft spa w/ 6 jets
    2HP Jandy pump, 60sq ft Jandy DE filter, 400,000 BTU Jandy LX Nat Gas Heater, 2 Jandy color lights + Jandy color spa light, Jandy Aqualink RS6, Jandy AquaPure 1400
    Don't worry about the PH while the FC level is very high. Wait till FC is back down to 10 or below and then test the PH again. High FC levels will cause the PH to read higher than it really is.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Don't trust your pH reading when the chlorine is high.
    Sep 2007
    141
    thanks guys....i'll let the FC come down to normal range and check again in a day or two.
