Thread: return fitting replace waterfall planter
    May 2012
    Jackson/New Jersey
    43
    I have an inground pool that the previous owner had a hollow rectangle flowerpot 4'x1' poolside waterfall. It uses a return pipe that has a vavle on it. It sticks out of the concrete surrounding thepool, about 4 inches with a 2.5 coupler. I never liked it, is there any info on a hollow boulder that I could attach the line to? Everything that I see online has a pump included which I don't need.
    Thanks for any help/ideas!
    Brian
    25,000 gallon, in-ground, vinyl liner
    Hayward S244T sand filter
    Hayward super-pump 1.5 Horse
    Hayward Aquarite SWG
    Pool construction 1999
    It sounds like your looking for something to cover that pipe Check azponds.com
    The have these hollow plastic bolder looking covers that you could easily pop a hole in for like a pipe
    I think I might have even seen them at the big box stores like lowes before but not positive?
    18' x 33' Aqua leader AGP (~19k gal) w/hayward swimpro voyager cartridge filter and 2hp hayward pump.
    8 Gal LQ, hayward heater.
    38,475
    Re: return fitting replace waterfall planter
    Sounds like a perfect setup for some of the fiberglass rock waterfalls. They overhang part of the pool and have a couple pieces. At my old house a large boulder was the water fall that had the pipe come up out the top and another piece set on top and put the pipe out of view. They are painted to look natural and very sturdy to even walk on.
    Don't have any pix available right now.
