Thread: World's Largest Pool
    http://goo.gl/8WVtO
    How many jugs of chlorine will we need??
    Gary R.
    18 X 32 Oval Inground Gunite Pool 20,000 Gallons Epoxy Painted in 2012
    Tagelus Sand Filter TA 60 D/TA 60-Hayward Super Pumps 1 H.P.
    Ray-Pac Heater 266,000 BTU, KLeen Machine Pool Cleaner
    Solar Cover-Rocky's Pool Cover Reel-Intermatic T104R Timer
    TF-100 Test Kit-PoolSkim Skimmer
    Mar 2012
    Amarillo, Texas
    341
    Re: World's Largest Pool
    I wonder what the enviromental effect of having a pool that large located next to an ocean is. It's beautiful, but I'd hate to have to clean it after a hurricane or something.
    18'x48" AG
    Pentair 1 1/2 HP Dynamo Pump
    Sand Dollar Sand Filter w/ Zeobrite
    Lil Shark Vacuum System
    Hard Plumbed
    May 2012
    NW PA, halfway between Pittsburgh and Erie in the PA snowbelt
    159
    let-s-have-some-fun-worlds-largest-pool-t44338.html
    Already noted in that thread that it would take 4277 gallons of bleach to raise from 4ppm to 7ppm FC.
    Mike
    22' round Intex UltraFrame pool, Intex 633T 2500gph paper cartridge filter/pump
    with broken Intex SWG, using bleach this year
    TF-100 test kit
    May 2011
    Montgomery, TX
    176
    it uses sea water
    "Chile's enormous pool holds 250 million liters (66 million gallons) of crystal clear seawater and uses a computer-controlled suction and filtration system to keep fresh seawater in permanent circulation, drawing it in from the ocean at one end and pumping it out at the other"
