Results 1 to 7 of 7
Thread: New intex pump won't start
    Just setting up a 16x48 pool for the kids and purchased the SWG sand filter system (CS15110).
    After hooking everything up the pump doesn't start or run. I have checked everything and water flows through the system with gravity, but keep getting code 90. Manual indicates possible flow sensor failure. I will call service center tomorrow but until then any ideas or is this a common problem?
    Thanks
    22,553
    Re: New intex pump won't start
    If the pump isn't starting at all it's definitely a warranty issue. It has nothing to do with the swcg it's all the pump. This is the first time I've heard of this happening on a new pump so it's not a common problem.
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    578
    This sounds like a dumb question but did you check the gfci on the pump plug? The Intex stuff is dumb that Everytime it is unplugged or power goes out you have to reset the gfci on the dumb thing.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    Quote Originally Posted by Jamison04
    If the GFCI was tripped he would have no power and wouldn't be getting the code.
    Definitely sounds like warranty issue to me. I have the 2650 sand filter/SWG combo and I have gotten air in the line occasionaly and lost prime on the pump. I'll get the code 90 when this happens and there is little or no flow but the pump is still running, just not pumping anything. If you're getting the code and your pump doesn't even try to start up, then it sounds like it's definitely a warranty issue.
    Intex Ultra Frame AGP 16'x48" 5,061 Gal with SWG 2500 GPH pump Cartridge filter
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    578
    I wasn't aware that it was a combo unit. Thought maybe they were seperate.
    No worries. I thought it might have been separate too at first but I know mine is a combo unit so I looked up his model number.
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    578
    Quote Originally Posted by donnie5336
    Then it definately does sound like he needs to contact intex on the warranty and get them going on replacing it or return it to the store and exchange it.
