Thread: intex pool pump
    intex pool pump
    I have a 1600 gal/hr intex pump for my above ground pool. I recently just installed an outside wall skimmer and I'm having trouble getting rid of air bubbles in the pool pump inlet. Have removed everything and tightened everything and still having air bubbles. I have a shut off valve below my skimmer and I notice the O ring in between that is a little smushed. Can that be causing air to be sucked in to the pump?
    38,305
    Re: intex pool pump
    Maybe. Try running a water hose over that area while the skimmer is on and see if the bubbles in the pump disappear.
    Re: intex pool pump
    you mean run it on the shut off valve
    38,305
    Re: intex pool pump
    Yes see if it pulls in water instead of air making the air in the pump go away.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
