Thread: Adapters
    Adapters
    I need a 2.5" I'd to 2"od adapter. I have a valve that I previously glued to a 2" piece of PVC and I re done some plumbing and now need to use the 2-1/2" od of the valve to connect a 2" union. I cannot find the adapter I think I need. Any ides?
    Bob
    38,548
    Re: Adapters
    You will need to use a 2.5" coupler to a piece of 2.5" pipe. Then a 2.5"/2" reducer to a 2" piece of pipe and then connect that to your union. This will probably require about 4-6" of space between the valve and union.
    EDIT oops ... you need a 2.5" coupler and then the 2.5"/2" reducer fits into the coupler and then use a 2" pipe to connect to the union ... should not need any 2.5" pipe.
    May 2011
    Orange County, CA
    696
    Re: Adapters
    What Jason said. 2.5" coupler to a 2.5 to 2" reducer bushing. I tried to find the latter at Home Depot without success. 2" seems to be the largest standard PVC stuff they carry. I ended up getting the 2.5 to 2 inch reducer bushing from a local Ferguson's plumbing supply, but I imagine you could find this at any local plumbing supply house or online.
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
    Re: Adapters
    agreed, and thanks. I cant seem to find them...
    Re: Adapters
    I think I have what I need. I am going to buy online from SpudTech.com
