Thread: Getting ready to add borates...
    Aug 2011
    Clovis, Ca
    31
    Heres where im at, pool is plaster, 18,500 gallons and just under one year old.
    I have been on BBB since day one so Im pretty sure ive got this process down.
    Tests as of today TF100 Kit, new chemicals;
    temp 81
    FC 4
    CC 0
    pH 7.8
    TA 190 (high)
    CH 300
    CYA 35
    Looks like I need to lower my TA, by pool calc I get adding 99 oz of MA and areation to get to 7.1 . Correct?
    Any clue as to how long i need to hold this low pH?
    Brand new IG gunite and plaster approx 18,500 gallons measured at fill from H2O meter.
    Clean and Clear Plus Cartridge 420 CU.FT.
    IntelliFlo VS-3050 VS+SVRS Pump
    Polaris 280 Cleaner
    Intellitouch automation
    TF100 Test kit
    30,426
    Re: Getting ready to add borates...
    It's a see-saw sort of thing...
    you lower pH to 7.0 or 7.1
    then aerate until pH rises to about 7.6
    Repeat by lowering back down to 7.0 or 7.1
    Then aerate until pH rises to 7.6
    Each time you lower ph, the TA will lower too, but, when you aerate, only the pH goes back up.
    Aug 2011
    Clovis, Ca
    31
    I may need little airation then, this darn pool climbs in pH prety quick on its own.
    Off to add MA and turn on the fountains.
    Thanks!
    Polaris 280 Cleaner
    TF100 Test kit
