Results 1 to 7 of 7
Thread: How many drops in Taylor reagent bottle?
    Apr 2012
    49
    Does anybody know how many drops (on average) are in either the .75 oz or 2 oz bottle? I am getting ready to shock and want to get an understanding of how much reagent I might need when I am using 48 drops every time I check FC levels over the multiple days I will need to test. I want to make sure I order enough, but don't want to order more than I need to.
    ____________________________________________________________ ___________________
    21,000 gallon in ground rectangular plaster pool, Sta-Rite High Rate Sand Filter Model 82524-3, AO Smith SK1152 1.5HP motor w/ Sta-Rite bronze pool pump, Hayward Navigator
    30,403
    Re: How many drops in Taylor reagent bottle?
    .75 oz = 22.4 ml
    24 drops per ml
    24 drops per ml, so the 0.75 ounce bottles have 532 drops (give or take).
    Apr 2012
    49
    Thanks to both of you for your quick responses.
    The math works out to about 1,419 drops for a 2 oz bottle. At my shock level of 24 ppm at .5 ppm per drop I will be using 48 drops each time I test. If I test 4 times a day I will only get 7.4 days out of the 2 oz bottle. I may need to splurge and buy the 16 oz size which will get me 59 days worth of testing at the same rate. Is that what most people do?
    Apr 2012
    49
    So now....does anyone know how many scoops in the 10 gram DPD powder?
    30,403
    Absolutely not. You will test a lot initially but you should have no reason to test more than once daily if your pool is clear.
    The absolute, definitive and precise answer for the scoops of powder in 10gms of powder is "A lot!"
    Apr 2012
    49
    Thanks.
