Results 1 to 8 of 8
Thread: I suppose I should get this out of the way...
    Apr 2008
    UhhhHiya
    26
    Hi all,
    Been reading up on the forums here and found lots of helpful info. I just recently bought a house over the winter with a 10x30x4 oval (well, at that point, rectangular with rounded edges) above ground. I'm no stranger to pool maintenance - the 'rents had one that I had to take care of, however I was using the TIC method. (Toss In Chemicals)
    With my own pool now, i'm going to concentrate more on getting the right chemical balances to keep the thing sparkling clean. The pool came with a newer sand filter, and a newer pump, and one of those nifty solar pool heaters that gets mounted on the roof of the garage.
    I'll post pictures soon. 8)
    10,600 Gallon 12x32x4 Above Ground
    Hayward Veri-Flo sand filter
    Hayward 1hp pump
    Taylor k-2006
    Jul 2007
    Va.
    76
    Welcome to TFP
    15x30x54 AGP, Hayward 1hp 2 spd pump, cartridge filter, Royal Entrance steps,Pool Rover Jr
    30,408
    Antares,
    Welcome to the forum. I have two thoughts after reading your post.
    1. I think your location is puzzling and we need more info
    2. I really like your acronym "TIC" To my knowledge, that's never been used on the forum before and I think we should all make it part of our jargon. I plan to use it frequently.
    Apr 2008
    UhhhHiya
    26
    Thanks for the welcome. "UhhHiya" is that there state just under Lake Erie, to the right of Pencilltucky, and to the left of Indeyaner.
    Remember, TIC is not just an acronym, its an entire pool maintenance method! It involves a strict discipline of never touching any test kits, and tossing in whatever chemicals you think might get rid of your cloudy mess.
    Hayward 1hp pump
    Taylor k-2006
    Butterfly's Avatar
    South Carolina
    10,045
    Antares, too funny
    Welcome to TFP!
    Pix soon?
    You're done SLAMing when:
    30,408
    Antares,
    Welcome!!
    I used the TIC method for a long time... great if you're going for that swampy green look!!
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Welcome to TFP!
    TIC - I love it. I use a similar method when cooking.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
