Thread: Leslies 81-330
    Leslies 81-330
    Thanks for your forum and Pool School!
    I purchased a Leslies Complete Pool Care DPD Test Kit for $70 because I was impatient. Now I realize that it is not really measuring my Chlorine accurately. I can't spend another $70 on the K-2006, so can you recommend a cheaper solution to bring this kit up to speed with the kits you recommend?
    Above Ground w/SWG
    24 ft / 12,500 gal
    Sand Filter
    Aug 2010
    Dallas, TX
    4,052
    Re: Leslies 81-330
    May 2012
    York Pennsylvania
    45
    Leslies 81-330
    Kit K-1515A. That's what I did. Same kit as you. $26 delivered in 3 days to PA
    Dave S
    24x52" Round AGP
    Hayward S244T 300 pound sand 1 HP matrix pump
    Taylor K-2005 Test kit with the K-1515-A FAS-DPD added on.
    No one is useless, you can always serve as a bad example!
    Re: Leslies 81-330
    Ordered. Thank you both!
    Above Ground w/SWG
    24 ft / 12,500 gal
    Sand Filter
