Thread: Hayward ec50 DE filter gasket question...
    May 2012
    Endicott NY
    87
    I just cleaned the inside of the filter and ready to put it back together and have a question.
    Do I install filter/fingers gasket that seals the top on dry? Or does it get a lube on the rubber like o rings? This is the rubber gasket all the bolts on top go through to seal the canister and the top together.
    Geo
    21 10500 gal AGP 52' sides, haward 3/4 hp xl pump and earth filter ec50
    Using the bbb method. Tf-100 kit. My first pool so learning in progress!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Hayward ec50 DE filter gasket question...
    I have always used silicon lube, don't know if it needs it or not.
