Thread: Seem to have gotten it in time...
    Jun 2008
    Marana, AZ
    347
    Had the stomach flu on Monday, recovering on Tuesday, and then worked 12 hrs on Wednesday. So this morning was the first time I was out to the pool since Sunday evening. (!) I had put pucks in a tri-chlor "floating duck" last week since my CYA had gotten low through backwash and splash-out, but the pucks had dissolved before this AM. However, even though the chlorine is low, the water looked pretty good. Maybe a little bit of green algae growing in a few spots (hard to tell whether it was algae or dust) but the water itself is clear. I put 24 oz of 10% chlorine in the pool (enough to raise it by 2 ppm) now; will put in more later after I swim. Because of my sensitive skin, I really need to keep the chlorine around the min mark for the CYA level around swimming time. Also need to put in some MA, but didn't want to put it in at the exact same time as chlorine
    Readings are (before putting in the 24 oz of chlorine I just put in):
    FC - 1.5
    CC - 0
    TC - 1.5
    pH - 7.8
    T/A - 110
    CH - 200
    CYA - 35
    Should I shock, even if it turns out that there was no algae, only dust / pollen?
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    Aug 2010
    Dallas, TX
    4,052
    Re: Seem to have gotten it in time...
    I've done that. You should be fine.
    22,551
    If it was me, I'd run an OCLT just to be sure. That way you don't have to wonder if you should!
    Mar 2012
    Amarillo, Texas
    341
    Could you possibly be more sensitive to the PH than the chlorine??
    18'x48" AG
    Pentair 1 1/2 HP Dynamo Pump
    Sand Dollar Sand Filter w/ Zeobrite
    Lil Shark Vacuum System
    Hard Plumbed
    Jun 2008
    Marana, AZ
    347
    Quote Originally Posted by mpacheco72
    Possibly. I know it tends to run a little high because of a combination of high pH in the fill water and the wind blowing most the time. I wear goggles when I swim; what I have an issue with is skin drying out fairly badly.
    Hayward sand filter
