Thread: Pump Selection
    Pump Selection
    Looking for a replacement pump.
    From what I have read here a 1HP 2-speed pump would be more than enough for my needs.
    Pentair/Sta-Rite have the OptiFlo and Dynamo in 1HP 2 speed models.
    Pentair Dynamo 340204 - Sta-Rite Dynamo 340060SR
    Pentair OptiFlo 347990 - Sta-Rite OptiFlo 347991SR
    What are the real differences between them?
    Are there other pumps I should be looking at?
    Where to purchase online for a good price?
    Also, can anybody tell me what the GPM would be in low speed given a Head of 30-35? (filter psi is just over 13)
    All the charts show high speed flow with no mention of drop for low speed.
    This is my third season with this setup, the pool has been up and running since mid April.
    The pump just started turning itself off and on (overheating I believe).
    16'x28'x54" oval pool
    13200 gal
    Sand filter (2 sq feet, 150lbs, max 25 PSI)
    1 skimmer and 1 return
    Resin Matrix 24'X54" AG, 22" Sand Filter and trusty Intex SWG
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Pump Selection
    Head curves are slightly different but the main difference is in the pump basket. I like the Optiflo design better.
    The filter pressure and plumbing head loss is dependent on the pump you have now so once the pump is changed, the filter pressure and head loss will probably change so you really can't use the old's pumps numbers unless it is one of the pumps you are considering. However, on typical AG plumbing, both pumps will produce around 48 GPM.
    Mark
    Re: Pump Selection
    Thank you for your quick reply.
    22,544
    Re: Pump Selection
    Welcome to TFP.
    I know a couple of Cormier's. One of them is named Bob!
    I'd listen to Mark if I were you. He knows his stuff!
    Re: Pump Selection
    I have ordered the Pentair OptiFlo 347990. Hopefully it will pay for itself in about two years.
    Re: Pump Selection
    Thank you for your comments.
