Thread: Considering a robot to replace Polaris 360...
    We currently have a Polaris 360 in our pool which is a long lap pool, about 45 feet long, ~11-12' wide with a separate spa on the end that is an additional 5' or so but walled off with a full width overflow. I've run our cleaner but it tends to get stuck in the corners a lot and I have to adjust our valves a bit to get it working properly so I'm a little frustrated with it and have been pondering a dedicated robot cleaner instead...
    Are there any recommendations on what is the 'best' and that would work on a pool of this dimension/shape? Perhaps consider two choices, best bang for the buck and all-out best w/no cost limitations. My concern is that maybe this long of a pool may cause some issues with cord length or any devices just tending to favor one side or something so thought I'd throw out a general inquiry with that in mind, for now I'll do additional browsing here...
    18-20k Gal (11.5 x 50 x 4.5'), IG Plaster, Cartridge, 3HP Pentair VS+SVRS
    Re: Considering a robot to replace Polaris 360...
    I am happy with a NC71 Smartpool Wall Scrubber 60.
    I am planning on plugging it into a timer to run two 3 hour cycles per day. It uses <150 watts
    I believe the cord is 60 feet.
    Easytouch, Intelliflo, Intellichem, Acid tank with pump, Intellichlor and Autelis network interface.
