Thread: Doughboy Wall 16x32
    Doughboy Wall 16x32
    Setting up my first pool which I found on Craig's list. the previous owner cut the wall along the joining strip, during the disassembly. I feel I did a decent job recreating the factory bends I even used a strip of welding wire to create a wedge. Has anyone attempted this type of wall repair and had success or failure? I am about to the point of installing the liner and hoping for a little feed back to either help me sleep at night or keep me awake.
    Thanks
    17,500 gallon 16x32 doughboy Aboveground
    West Michigan
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Doughboy Wall 16x32
    I assume you had too shorten the wall to do this? Depending how much play you have in the top and bottom rails, this may be a little tougher to fit. Thinking back to my pool (round), I think I would have been able to deal with a little shorter wall but not much more than 1" without some other modifications. On mine it seems like you could shorten (cut) a section of top and bottom rails to accommodate, but I do not know if you could make the ledge work...I think I could on mine.
    I would be interested on a picture of your re-creation...that joint has quite a lot of stress on it.
