Results 1 to 11 of 11
Thread: Mini Pebble Gets Installed Today
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    The remodel of our 1984 Shasta Pool has been ongoing for nearly a month now. Today we are finally at surface installation. Tomorrow will be an Acid Wash and then fill. It will be 108 here today, so really looking forward to having the pool finished. I will attempt to get some good pictures along the way.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    elwood58's Avatar
    May 2012
    654
    Re: Mini Pebble Gets Installed Today
    They finished the MiniPebble on Thursday, then did an Acid Wash on Friday. It took 12 hours to fill it up. Startup is Monday. All I do now is sweep, sweep, sweep
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Looks great!
    which minipebble color did you get?
    Dave
    elwood58's Avatar
    May 2012
    654
    The color is Aqua White. A bit of a misnomer, as it looks more like light blue when applied and lightens as it cures.
    Oct 2009
    3,899
    Looking at your picture again, I can't believe you have a teddy bear cholla by your pool...must be hard on the inflatable toys!
    elwood58's Avatar
    May 2012
    654
    Quote Originally Posted by Melt In The Sun
    That was there when we bought the place, and has a bird nest with eggs in it. When the babies hatch and leave the nest, the cholla will be removed.
    Apr 2010
    Buckeye, AZ 85326
    619
    Looks great, I really like the U shaped entry!
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    elwood58's Avatar
    May 2012
    654
    They started up the pump and finished some plumbing on the auto leveler Monday. It is looking good so far. They should be out tomorrow to put in the popups and do an overall balance of water chemistry. Salt system is in (Pentair), but will not get started for three more weeks.
    elwood58's Avatar
    May 2012
    654
    Quote Originally Posted by Shane1
    It doubles as a cold water spa, with a bench and therapy heads all around.
    elwood58's Avatar
    May 2012
    654
    Another shot, post startup.
