Thread: Totally stumped...
    Totally stumped...
    My boss at work asked me to check out his pool as he had been having issues with it for several years. I told him about TFP and that I had a Taylor test kit. He has an approx. 13,000 gallon fiberglass in-ground with a sand filter, .7 hp motor, inline auto Dichlor chlorine feeder. So, I go to his house yesterday after work and after testing get the following results;
    Water was very clear and by appearance alone everything looked good, but
    FC .5
    CC 11.0 !!!
    TA 40
    PH 6.8
    CH 170
    CYA way above 100! (The dot disappeared after only about 3/8 of water in tube, way below the 100 mark)
    I have been reading this forum since I installed my pool last spring and I have yet to see test results anything like I have here. He has had this pool about 10 years and said he struggles with it every year, from cloudiness to wall staining from metals and said this year hed like to get on top of it. I thought Id be able to go there and give him my recommendations from all Id learned here at TFP, but in all honestly these test results left me scratching my head. To top it off, he took his water to 2 different pool stores and they both told him his CYA was 30. I know pool store results can be wrong, but to both be wrong by the same amount has him wondering which test is correct, the pool store or the Taylor. Considering he has been using Dichlor for many years and has never done a drain/refill I am pretty confident my test is the accurate one but anyway, assuming it is, what are we likely dealing with here? Ammonia maybe? He has added over 24 gallon of 10% liquid chlorine over the last several days in an attempt to get a chlorine reading with his test strips (I told him to get a good test kit) but from what I can tell it quickly becomes combined chlorine and the Free Chlorine reading stays low. Being that the water is completely clear yet the readings are so out of whack, I am a bit stumped. Any advice is appreciated!
    Edit: Does CYA testing reagent go bad over time? Mine kit is about a year old.
    Brian
    mtheaded's Avatar
    Oct 2007
    Lovettsville, VA
    46
    Re: Totally stumped...
    I think I'd start with adding enough Baking Soda to bring the ph and TA back into normal range then run all tests again.
    26,000 gallon IG Vinyl Lined, Hayward DE2400 Filter, Hayward SP2610X15 1/2 HP pump, Dolphin Sprite robot, open May to October
    Jan 2010
    Randleman,NC
    620
    I think I would be looking for a new job by the time you figure out what's going on..."The Boss"..Because he going to think you are wrong...I have learn'd over the yrs. of taking care of my pool.That I have been nice to go check friend's pool's who complain all the time about there water&I tell them what need's to be done & they think I'm a joke.."Bleach"&need to drain half the pool cause's CYA is out the roof&they want to know why they can't get it to clear up.They never do what I suggest..That's why I have stopped checking people's pool's.Sorry,you may be out of a job in the near future.Your if he is really nice&you get it fix'd you may move up the ladder to "The Pool Boy" for the boss.lol
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    Jan 2010
    Randleman,NC
    620
    Quote Originally Posted by mtheaded
    But, all laugh's aside I would do the same thing..Good Luck.
    22,544
    First thing to do is get the pH up to the mid 7's and then tell him he's going to have to drain at least half his water. I wouldn't even begin tackling it till you get the CYA to something reasonable like 50 or less.
    To get an idea just how high the CYA is, dilute the sample half and half with tap water and test it again. multiply the result by 2..
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
