Thread: salt water
    wolfy's Avatar
    May 2012
    Randleman, North Carolina
    33
    salt water
    I have read somewhere others have used salt water without a salt water generator. That some pools with a regular pump can handle salt water. Read the intex pump the pool comes with is all they used. Wondering If anyone here has experience with this?
    15x42 intex metal frame pool
    16x48 Intex Ultra frame pool with swg
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Re: salt water
    Are you referring to adding salt to a chlorine managed pool?
    Some people add pool salt to a regular BBB pool in order to have softer water, I was planning on trying this summer. I believe this is one area where a salt test strip kit is adequate. My understanding is that, done right, it doesn't make the water "salty".
    wolfy's Avatar
    May 2012
    33
    Re: salt water
    No chlorine, pool is not up yet so I can start fresh.
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    Re: salt water
    We added salt for "feel" last year. Could tell a difference. Will add it again this year. We used 80lbs for our pool that holds about 5400 gallons. I believe you want to aim for around 2000.
    ~~ Allison ~~
    Intex 18' x 48" Easy Set Pool, approximately 5455 gallons
    Krystal Clear 1500 GPH Filter Pump Model 56635EG - 635 with Auto Timer
    BBB FOR BEGINNERS ~ THIS IS A MUST READ FOR ANYONE OVERWHELMED!!
