Thread: will FC of 30 effect CYA test?
    Oct 2010
    michigan
    284
    using the tf 100
    wonder if FC of 30 will effect CYA test?
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: will FC of 30 effect CYA test?
    Quote Originally Posted by smooth2222
    No
    What problems are you having with the CYA test?
