Results 1 to 9 of 9
Thread: the numbers are in...
    Jul 2009
    Fort Wayne, IN
    392
    Just double checking myself to make sure I will be adding the right stuff tomorrow. The water is clean and clear. But the calculator says I need to tweak some things. Here are my current numbers.
    FC 2 (will add bleach to get this to 4 tomorrow)
    CC 0
    TC 2
    pH 7.9ish
    TA 180 (will add 136 oz muriatic acid to lower pH to 7.2, then aerate to bring pH back up) SOMEONE PLEASE MAKE SURE THIS PART IS CORRECT AS I AM UNCERTAIN
    CYA 39ish
    My pH has risen steadily since we put in the slide and deck jets. Also, we have been averaging 8+ kids in the pool everyday. Has all this natural aeration made the pH rise. Thoughts?
    Theresa and/or Gary
    Complete DIY: 20x40' rectangle. Resin walls, vinyl lined. 33000 gallons. Full width steps. 8' deep. Diving board, slide. Hayward pro series super pump, sand filter. Raypack 336K BTU heater. Main drain, 2 skimmers, 3 returns, 2 amerilite lights with quick change lens Aquamatic auto cover and a partridge in a pear tree.
    Breaking our backs in the hopes that one of our six kids will care for us when we are old ;)
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,065
    Re: the numbers are in...
    You are correct, both to the cause of the pH rise, and how to fix it. Just keeping pH adjusted down at the low end and running the slide and all should be enough aeration.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Just to add, remember to help ensure a trouble free pool, keep you FC above 3 ppm (from poolcalculator using 39 ppm cya) at all times.
    Jul 2009
    Fort Wayne, IN
    392
    Thanks everyone!
    P.S. richard, you have such a friendly face! Love seeing it pop up in my posts!
    Theresa and/or Gary
    Jul 2009
    Fort Wayne, IN
    392
    three hours ago, I added 164 ounces of muriatic acid. I retested and these are the new numbers
    pH in-between the two bottom colors
    TA 160
    How long should it take for the TA to lower to 100?
    Is there something else I should be doing, or do I just wait?
    When should I retest?
    Can the kids swim for a bit?
    Will they turn into yucky sea creatures if they do swim?
    They are all waiting on the deck in their mermaid suits!
    Theresa and/or Gary
    30,432
    If your have SOME chlorine in the pool and the water is clear, go SWIMMING!!
    You can typically swim within an hour of adding muriatic.
    Now, back to your TA. It won't lower any further until you perform the process described in pool school. Essentially, the next step is aeration so the kids should provide that. At the end of their swim session, I expect your pH to have risen back up but the TA will remain unchanged. It will lower the next time you add acid....then put the kids back in and have them splash around to get the pH back up.
    Read the article in Pool School.
    Jul 2009
    Fort Wayne, IN
    392
    Now I understand that it is a process. thanks!
    Theresa and/or Gary
    Richard320's Avatar
    Jan 2010
    19,065
    Quote Originally Posted by 8corneflakes
    If you want to speed it up, play around a little with some PVC pipe and make something like this
    I imagine the kids will be able to develop some sort of game involving a fountain or water jet.
    Jul 2009
    Fort Wayne, IN
    392
    the kids do that with the water noodles. good times!
    Theresa and/or Gary
