Thread: Tea color filter
    Tea color filter
    We just set up our pool this past weekend. I have only checked ph & chlorine levels and they are fine. I will be checking CYA this weekend to make sure it is at a good number. My water is clean and clear but I looked at my filter tonight and it is iced tea color. Could this be a problem starting to arise or is it just our dirty water where I live?
    Intex 18 x 48 Ultra Frame, 1500 gph Intex Krystal Clean filter pump
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Tea color filter
    It might help if you tell us what kind of filter you have
    Sorry, I changed my signature to include the pump type.
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    573
    It could just be what ever it is filtering out if the water causing it to stain or it could possibly be sunscreen or tanning oils if any body in the pool had that stuff on.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Do you have metals in your fill water (like from a private well). It could be that showing up in the filter...that happens to me.
