Results 1 to 10 of 10
Thread: Free Chart for Logging BBB Chemicals
    Hi,
    I'm sure some people have already done this but I just thought I'd throw this out there. I've just attached an Excel Spreadsheet that lets you log your pool levels daily throughout each month and tallies your Yearly Totals To Date. It's not much but if I can contribute back to the TFP community in this way I figure it's worth it.
    Attached Files Attached Files
    sbelgrave @ Westminster, MD
    Size : 16 x 32 x 4
    Volume : 12,000 Gallons
    Material :Vinyl
    Water Type : Non-Saltwater
    Feb 2008
    Denton, TX
    5,061
    Thanks for posting that. Should make for interesting data collection purposes for sure. I did make a spreadsheet to track my test results as well. Whatever keeps people organized is a big help. Now, if Jason could just put his pool calculator into a downloadable Palm version, all would be right with the world.
    Craig
    IkeRay's Avatar
    Houston, Tx
    154
    Re: Free Chart for Logging BBB Chemicals
    Quote Originally Posted by sbelgrave
    Hi,
    I borrowed your spreadsheet, I had just thought of doing one today coincidentally. I made some minor changes such as I added a tab for monthly/yearly trends (entire month added per column and divided by number of days), as well as added October, November, and December since I don't plan on closing down the pool this winter. thanks for the spreadsheet btw.
    30,000gal In-ground Gunite Pool DE filter
    Polaris 380 APC
    BBB method all the way - Newb, like to absorb info and chatter, but take the experts' advise
    Heheh,
    Yeah, Notice you live in Houston. Hadn't thought about year round pool maintenance. Good call
    Size : 16 x 32 x 4
    Material :Vinyl
    Oct 2007
    Philadelphia, PA
    86
    This is a great tool. Thanks for posting it.
    I do have a nitpick correction -- pH is dimensionless. It's shown as ppm on the individual month pages. Also, you don't add pH, you add something to change pH. So, listing amount of pH added in oz is confusing.
    11x27 in ground, vinyl pool
    ~12,500 gal
    PAC FAB (Pentair) Pinnacle 3/4 hp pump
    Pentair 24 sq ft DE filter
    One skimmer, one return (no main drain)
    IkeRay's Avatar
    Houston, Tx
    154
    I personally changed the pH to dimensionless and I changed the pH "change" to 2 categories, acid (in cups) and borax (in lbs). my daily chart has bleach in oz but my yearly added page has bleach and acid in gals.
    Polaris 380 APC
    Butterfly's Avatar
    South Carolina
    10,045
    Hi,
    Great idea! Thanks
    You're done SLAMing when:
    For those that found my errors, thanks for the corrections/notes. I figured I'd have a few of those Glad to be of help.
    Size : 16 x 32 x 4
    Material :Vinyl
    IkeRay's Avatar
    Houston, Tx
    154
    yeah, no worries, everyone misses some things when they release things publicly. even windows releases stuff that they missed some small things and have to release patches to fix them. i did some of the things i did to make it "my own" if you know what i mean...
    Polaris 380 APC
    Aug 2007
    Austin, TX
    341
    Outstanding and thanks for sharing!!!!
    I have been using excel now to track mine, you gave me a fresh idea. I felt I needed to share it with the masses since you where so kind to share. I hope there are not too many mistakes but oh well.
    Enjoy!
    20k Gunite/Prism Blue-Pebblesheen, Pentair Tagelus TA-100D Sand Filter, Heliocol Solar Water Heater, 2 bubblers and 2 waterfalls installed 2007, 3hp IntelliFlo VS Pump 011018 installed 2013, Aquabot Turbo T4 RC and Stenner 45MHP10 w/The Liquidator container installed 2012.
    Antigua Spa by Artesian Spas: 325 gl, 52 jets, 6 hp 2 sp & 6 hp 1 sp, Circulation System 24 Hour Whisper Pure, Ozonator, LED digital lighting, The Artesian Pillowfall installed 2007.
    Retired: 2hp Pentair Whisperflow, Legend Platinum w/booster pump, PH Adjuster
