Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: Sun and shocking
    esim13's Avatar
    Oct 2009
    Denham Springs, Louisiana
    320
    Sun and shocking
    Part 1:
    A little background first... Pool started clouding up Thursday. Had 4 swimmers Thursday evening. Left early Friday morning to go RVing. Came home late yesterday, pool still a bit cloudy with a hint of green. Algae is starting! Time to shock. Went to Wally World and loaded up on bleach. Am I fighting a losing battle trying to compete with the sun? I know I need to shock, but should I wait til this evening and hit it hard while the sun is down? Am I wasting bleach starting during full sun?
    Part 2:
    We just recently purchased a RV. We're both teachers so we'll be getting away quite often. What is the best way to handle the pool while we're gone? Up FC before we leave? Use floaters/pucks while gone?
    THANKS!!!
    10,408 gallon, 21' round, 52 in' deep AG, half in ground
    Artesian Clear Master Plus Sand Filter, Artesian Turbo King 2 hp pump, installed June 08
    GEAUX TIGERS!
    Pics taken 2012
    http://i941.photobucket.com/albums/ad25 ... CN0606.jpg
    http://i941.photobucket.com/albums/ad25 ... CN0607.jpg
    38,271
    Re: Sun and shocking
    What is your CYA level? If it is over 30ppm, that should help protect the FC from the sun while shocking. Starting in the evening is fine, but you need to maintain the FC over the shock level 24/7.
    If you are only going to be gone for a few days, bumping the FC up to shock level just before you leave may be enough. As the trips get longer, you may need to supplement the shock level with pucks in a floater ... understanding that they will increase your CYA.
    Feb 2012
    Phoenix, AZ
    728
    Can you post a full set of test results. Most importantly, what is your CYA?
    In short, the chlorine will be used faster in full sun, BUT shocking is typically a multi-day process anyways..so you might as well get started.
    When you are gone, there are a few options. How long are you trips? Pucks are okay..but will add CYA (and you don't want this to get too high). A SWCG would work too, but that is somewhat expensive. Another option is having a neighbor or friend to visit semi-regularly and put in small amounts of bleach. I am not sure what your pools FC consumption is like, so I don't know exactly what that dose would be. Ideally, the water would get tested for FC, and adjusted appropriately. This may not be an option if you are having a neighbor/friend maintain the pool.
    esim13's Avatar
    Oct 2009
    320
    Full set:
    FC 12.5 (I did add 2 big jugs of bleach about 2 hours ago.)
    CC 0
    pH 8.0
    TA 70
    CH 50
    CYA 20 (hit right at the top of the cylinder)
    GEAUX TIGERS!
    Pics taken 2012
    Aug 2010
    Dallas, TX
    4,052
    You need to lower your pH...
    You can use a floater with trichlor tabs with your CYA at 20.
    esim13's Avatar
    Oct 2009
    320
    Why does my pH keep rising? I lowered it to 7.4 Thursday before the swimmers got in.
    GEAUX TIGERS!
    Pics taken 2012
    38,271
    Splashing raises the pH.
    I would think you would be best served by raising the CYA to at least 30ppm and then starting the shock process (after lowering the pH).
    Aug 2010
    Dallas, TX
    4,052
    So true! I missed he had algae forming!
    esim13's Avatar
    Oct 2009
    320
    I figured pH was reading a bit high bc of FC. I'll keep at it!
    Thanks!
    GEAUX TIGERS!
    Pics taken 2012
    38,271
    You are correct that as FC get > than 10ppm, the pH test tends to read a little high. But you are close to 10ppm and are pretty high so the pH could use to go down a bit. You could let the FC drift below 10ppm and check pH again.
    esim13's Avatar
    Oct 2009
    320
    Pool is coming along fine.. maintaining shock level is right on. While I'm waiting for my next check I started wondering about my pH to TA ratios. I know I lowered pH before the swimmers got in the other day. I know splashing and such raises pH but here's the thing... no one was splashing. The swimmers were mid 30 women floating on noodles. Not much excitement going on, just chating as women do. Yesterday when FC dropped to 10 I retested pH before bumping back up to shock level. pH was still at 8.0. I fight the pH battle regularly. Is this normal? Will raising my TA help with maintaining a steady pH level? TA is currently at 70.
    Thanks!
    GEAUX TIGERS!
    Pics taken 2012
    esim13's Avatar
    Oct 2009
    320
    My high end FC says 14. Would it hurt anything if I bumped it to 20 for the night? I'm going out of town for the night Friday so I'm hoping to stay ahead a bit til I get back Saturday.
    Thanks!
    GEAUX TIGERS!
    Pics taken 2012
    38,271
    What do you mean "high end"? What is your CYA?
    esim13's Avatar
    Oct 2009
    320
    When I checked yesterday it was 20. I'm using Pool Calc app on iphone. High shock says 14.
    GEAUX TIGERS!
    Pics taken 2012
    38,271
    Oh ... ok. Shows as mustard shock level on poolcalculator online.
    Well, 20ppm may be a little high although may be fine for a 1 time occurrence. The biggest danger is fading your liner, although not probable for a single short high FC level.
    I am not sure what is a "safe" level honestly.
    esim13's Avatar
    Oct 2009
    320
    Ok, I'm thinking the same thing. I have it at 14 now so I'll wait and see if anyone else pops in before bed. If not I'll leave it for the night.
    THANKS!
    GEAUX TIGERS!
    Pics taken 2012
    esim13's Avatar
    Oct 2009
    320
    We're almost there...
    GEAUX TIGERS!
    Pics taken 2012
    Feb 2012
    Phoenix, AZ
    728
    Quote Originally Posted by esim13
    Yes, you are!
    esim13's Avatar
    Oct 2009
    320
    I'm about to leave for an overnight trip and hate to lose momentum. I have no one around to add bleach. Any suggestions? Should I up it before I head out and hope for the best when I return tomorrow evening?
    GEAUX TIGERS!
    Pics taken 2012
  20. Back To Top    #20
    esim13's Avatar
    Oct 2009
    320
    One more question.. If my pump is running at 11.5 then I backwash around 14?
    GEAUX TIGERS!
    Pics taken 2012
