Thread: new pool decisions..comparison
    Hello all- We are trying to figure this pool thing out and were hoping for some thoughts on our choices. Here are is the equiptment in our two bids:
    choice #1:
    Pump: Zodiac Flo Pro Variable Speed 2H
    Filter: Zodiac 460 Sq Ft Cartridge Versa
    Control: iAqualink PS8
    sanitizer: nature 2 plus fusion
    Ret Cleaner: Polaris 280
    choice #2: (all pentair- this bid has less detail re equiptment)
    Pump: 2 HP with GFCI
    control: easytouch wireless
    legend cleaner
    Pool is free form, about 35x19, about 95 linear feet (bids are a bit different in size)
    Thanks!!
    38,548
    Re: new pool decisions..comparison
    Welcome
    Those are hardly comparable as there is no information in Choice #2 (what filter, which pump, any sanitizer).
    I will say this. Do no waste your money on the Nature 2 plus fusion. First that type of chlorine (pucks/sticks/etc will add stabilizer (CYA) which can be bad if levels get too high) and second the "minerals" are just copper and silver which are not needed in a pool and can lead to staining and green hair if not controlled.
    If you are going to have the iAqualink, why not get a SWG?
    Also 2HP seems pretty big if you do not have a spa or water features.
    If you are interested in learning before you get your pool, Read through Pool School (button at upper right) a few times. There are articles in there that explain the chemistry in your pool and what is recommended to use to chlorinate your pool.
