Thread: My dads pool
    Mar 2012
    Eastern Long Island,New York
    82
    My dads pool
    Following test results with tftest kit:
    Ph 7.2
    FCC .5
    Cc. 0
    TA 70
    Ch 20
    Cya 37
    Salt 3000
    Just converted to salt. Ready to turn on.
    Any suggestions
    Thanks
    20 X 40 Vinyl IG 28K gallons, Heat Siphon Z700HP, Hayward 4820 DE, Hayward SP3400VSP, Jandy aquapure 1400, TFTest Kit, Pool School, Pool Calculator
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: My dads pool
    Does converting to salt also mean you have added a swg (salt water chlorine generator)? If so, have you reviewed the Water Balance for SWGs yet?
    Mar 2012
    82
    Re: My dads pool
    I did but being its for my father I'm not here to often and I don't want to screw it up
    38,475
    Re: My dads pool
    Well, if you are not going to be maintaining the pool, I would suggest you get him to start reading as well.
    Or you may end up in a situation where it is somehow your fault when the pool goes green.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: My dads pool
    I agree with jbliz that it would be best if your father also is on board with the tfp methods.
    Looking at your (fathers) test results, two things jump out at me:
    1. CYA of 37 is fairly low. Our recommendation is 70-80 for a swg. Remember easy to add, drain/refill to remove.
    2. Ch is low...what kind of pool surface does your dad have. If it is vinyl, I would not worry about it. Plaster or fiberglass and you should adjust it upwards.
    Aug 2010
    Dallas, TX
    4,052
    Re: My dads pool
    Also, QUICKLY get some Clorox/bleach in there to get FC up to 3 or 4. .5 is too low.
