Results 1 to 9 of 9
Thread: We might have made a big mistake with Cozy Cove jets
    We are installing a 16 x 32 Hydra pool with a Cozy Cove, and a pool contractor is helping us with the dig, installation of the pool bottom, liner and concrete. He has no experience with Cozy Coves, however. We decided to install the jets about 4 inches above the bottom of the divets in the Cozy Cove (see picture). We thought it might be nice to have the water spray on the middle part of our backs. But now, we think that was a mistake. We realized after looking at Hydra’s sample Cozy Cove picture (see attached), they put the jets at the bottom of the divets, and the water barely covers them. We are concerned that we won’t be able to keep the water level high enough to cover the jets if we leave them where they are. Should we move them down? If so, what should we use to patch the extra holes we made? If we do this, we need to do it now because we’re about ready to put in the rock and concrete! We really need some advice! Thank you!
    [attachment=1:3b9utc0z]Cozy Cove jets.jpg[/attachment:3b9utc0z]
    [attachment=0:3b9utc0z]cozy-cove-spa.jpg[/attachment:3b9utc0z]
    Jul 2011
    St. Paul, MN
    244
    Re: We might have made a big mistake with Cozy Cove jets
    What is the level of the cozy cove jets compared to the level of your skimmers? Your water level will be roughly half way up the skimmer opening.
    20'x40' Oval 27,000 gallon Vinyl IG, Coverstar Auto Cover
    Hayward MaxFlo SP2303VSP, Sta-Rite PLD50 30 sq. ft. DE filter
    Rheem 266,000 btu natural gas heater
    Dolphin Nautilus Plus with Clever Clean
    TF-100 testkit w/ Speed Stir
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    I can't find an online installation manual, did it not come with one?
    What material is it made out of?
    What is the distance from the top of pool walls to middle of skimmer? What is distance from top of pool wall to top of jet on cozy cove?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    38,267
    It looks like where you have then will still be under water (based on the sample picture). Of course, being a return, even if they were above the water level, they would still work.
    I think you would be asking for more trouble trying to patch holes if you moved them.
    It's fiberglass. And didn't come with an installation manual! It's been one of those learning experiences. The middle of the skimmer is about 5 1/2 inches from the top of the wall. The top of the jets are 6 inches from the top of the back of the Cozy Cove. So I guess we're okay. I think you're right about asking for more trouble trying to patch the holes. Thanks for the advice!
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    I wonder if you could raise the skimmer a tad?
    Or just run the water level a little higher up the skimmer than normal.....
    18'x43' Sport Pool
    That sounds like a good plan. We'll try that.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    So what ever happened?
    18'x43' Sport Pool
    When the water is filled halfway up the skimmer, it ends up being about a 1/2 inch above the jets in the Cozy Cove, so it's fine. Thanks for your advice, it was right on the money.
