Thread: Shock green swamp
    May 2009
    Trenton NJ
    497
    Shock green swamp
    How often should I add bleach? FC is zero and I used the sock method for cya 6 lbs. I been dumping 3 gallons 3-4 times a day since yesterday. I am not getting ahead of algae.
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,089
    Re: Shock green swamp
    Do you have a good test kit?? If so what are your current numbers? For us to answer that question would be like answering "how far is it to New York?" We have no way of knowing just how far you have to go to get there at all.
    May 2009
    Trenton NJ
    497
    Yes,Taylor 2006. I will get on it. Just test for FC at this point,correct?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    You may need to add bleach every hour to maintain a high enough FC level to kill the algae faster than it can reproduce. How high that level is depends on the CYA level.
    If you don't have the proper test kit, you're wasting a lot of time and a lot of bleach.
    Start reading pool-school/ to gain an understanding of what I just wrote
    It CAN be done. Here's a recent thread with some before and after pictures that should inspire you
    Jul 2011
    Eastern Ohio
    7,089
    Test your PH, CYA, FC, and CC to start.
    May 2009
    Trenton NJ
    497
    Sorry,I haven't had a green pool since last year and I am rusty. I put 6 lbs of cya in yesterday. My FC is 12.5 right now. Put 3 gal.bleach 1 hour ago. My cc is .5.
    My cya was zero yesterday so can't test that yet since I just put some in.
