Thread: GotOneRunning
    May 2012
    Loudoun County, VA
    1
    GotOneRunning
    New homeowner that came with pool.(Previous owners did not open it since 09. Short sale home) So far, it's been a nightmare. I had a company come in 3 times now and they seem to do the same thing. Throw some shock and chlorine tabs and call it a day. They refuse to vacuum the bottom of my pool, because the debris is too thick and they are scared to drain too much water on waste since it's a vinyl pool. Any suggestions about vacuum techniques on vinyl pools? The water is green and cloudy right now.
    23,500 GAL, IG, Vinyl, FNSP 36 DE Filter
    Re: GotOneRunning
    Welcome to TFP!
    For thick debris a leaf net is more effective than vacuuming. The vacuum will clog very quickly.
    If you haven't already, take a look at How to Turn Your Green Swamp into a Sparkling Oasis.
    Re: GotOneRunning
    Sounds like the exact story with our house. This I do know - The old home owners were dumping the lawn clippings in prior to losing the house on top of not opening it for two years.
    I spent about two hours every day when I got home from work for two weeks to get all the debris out of the bottom. The pool was green & I was doing it blindly, so I brushed everything to one side, then scooped it up with a deep net. The guys you talked to were right. Don't drain the pool down & I wouldn't run the pump until most of the debris is out.
    You should get a water sample & take it to your local pool store for a good reading once you get that junk out. If your pool is that green, with leaves & stuff, then shock isn't going to do too much. The algae will eat that chlorine right up.
    26,000 Inground Vinyl, 16' x 32'. Pentair Intelliflo SVRS, with 30" Hayward Pro Sand filter.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: GotOneRunning
    Welcome to tfp, Gotonerunning
    Definitely get the leaf net out and get as much of that organic material out that you can. It will take a lot of work, but will be worth it. Let us know if you have questions.
