Thread: Updates on how they like their AutoPilot
    Yes, you should have started a new topic. Topic split off. JasonLion
    Not sure if I should have started a new thread instead of reviving this one, but thought perhaps after a year someone may have some updates on how they like their AutoPilot.
    So Iím down to either the Aquarite pro or Autopilot DIG-48. The only reason aquarite is still in the mix is that with that unit you can add a PH control unit later and my understanding is that with Autopilot it would require replacing everything to go with total control. Is that correct?
    Also, I currently have 220 service for the pump and was thinking of tying into this for the Autopilot. Does the autopilot perform better on 220 vs 110?
    Ft Lauderdale, Florida
    1,455
    Re: Autopilot Digital vs. Aqua Rite
    dvmak, you can start with the 75003 Digital, and upgrade to a manually controlled pH control option, or a fully automated Total Control system. However, it starts out with the 75003 instead of the DIG-220.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Re: Updates on how they like their AutoPilot
    The AutoPilot units don't really care which voltage you use 120 or 240.
