Results 1 to 7 of 7
Thread: Don't have enough suction for skimmer
    I have a hayward pump and triton sand filter- not that old. I opened the pool to find bubbles on return. sealed up everything I could think of- finally no bubbles- had enough suction to vac through waste, but now I have no pressure.... waste line was working the other day when vac and backwashing, but now does nothing- no water comes out at all.. tried a bladder, you name it and still don't have enough suction for skimmer to keep top clear.. have a huge college graduation party and son Commissioned as 2nd LT- headed off to GA for 8 month and I have tons of people coming for a pool party.. how to I fix this quickly???
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Don't have enough suction for skimmer
    Does the pump sound normal otherwise? Does the pressure gauge move? I'd look for a clog on the suction side since you were vacuuming. There might be a wad of leaves or something stuck in a pipe elbow, or in the pump impeller.
    22,544
    Welcome to TFP.
    I suspect as Richard does that it's a suction clog. Since you said you used bladder to try and clear it I'd suspect the impeller is clogged.
    I did not try the bladder on the imppeller side.. I was afraid to damage something. I did have a little pressure, but not nearly what I normaly have. Mind you this is an extremely old pool- concrete... I put a brand new system in about 7 years ago and has only given me a little trouble- usually nothing I couldn't handle on my own... I am trying to find a new O-ring-there is a bit if hissing- is that enough to mess with the suction on the skimmer..?
    22,544
    Yes a piece missing from an o-ring will definitely cause a problem.
    I checked the o-ring.. looks perfect, but I am going to replace it anyway. Haven't replaced the sand in a while would this be a contributing factor??? I just think it's bizzarre that it was working, I was able to get some vacuuming done and then it started to act up... pressure gauge may be fritzed out but it was registering some pressure... now below 5...it's usually around 10-15...
    22,544
    I still suspect an impeller clog. You're most likely going to have to pull the casing off the pump to get at it. You may be able to see into the vanes by pulling the discharge piping off it.
