Thread: Epoxy Paint Yellow Stain
    Hi to all;
    Pool was recently epoxy painted including some old plastic coping. We're seeing one 4" or so yellowish stain on the pool floor and some of the same on the old coping. I'm assuming this may be from a fairly short cure time, about 5-6 days, due to weather concerns and the possibility of pool popping. I think the staining is a bit of bleed through from the epoxy.
    Chemical numbers are good, ph, ta, etc.
    If this is epoxy bleed through is there a way to remove the stain?
    Thank you!
    Gary R.
    18 X 32 Oval Inground Gunite Pool 20,000 Gallons Epoxy Painted in 2012
    Tagelus Sand Filter TA 60 D/TA 60-Hayward Super Pumps 1 H.P.
    Ray-Pac Heater 266,000 BTU, KLeen Machine Pool Cleaner
    Solar Cover-Rocky's Pool Cover Reel-Intermatic T104R Timer
    TF-100 Test Kit-PoolSkim Skimmer
    22,543
    Re: Epoxy Paint Yellow Stain
    If it's bleed through, I'm afraid there's not much you can do about it.
    Thanks Dave, I did find the following from a pool supplier:
    Stains occasionally appear within the pool coating, commonly yellow in colour, as a result
    of excess amine (hardener) leaching to the surface of the coating. This staining can occur
    about one month after the painting is completed. The stain will gradually disappear as
    the pool chalks. This will take approximately 2-3 months during summer and 3-4 months
    during winter.
    Love the TFP forum!!
    Gary R.
