Results 1 to 7 of 7
Thread: another cya question
    May 2009
    Trenton NJ
    497
    I read in the other post that you lose cya due to splash out and sometimes over the winter. When I closed the pool last fall my cya was around 60-70. I opened today and tested with my taylor kit, no cya. Possible to lose all cya over winter?
    I am currently putting in 6 lbs. I know I will need more. What does 6 lbs. get you?
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    38,489
    Re: another cya question
    We have seen that happen before here on the forums. Could mean that it was all converted to ammonia which will require a lot of FC to break it down (or sometimes not).
    According to the poolcalculator (at the bottom) adding 6 lbs to a 20k gallon pool should give you 36ppm CYA and lower pH by .67
    If you need to go through the shock process, do it with this lower level of CYA BEFORE you raise it higher to the SWG recommended levels.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    This can be common when you have a swamp like pool, there are bacteria that can convert all your CYA to Ammonia, chlorine will react with the ammonia and be consumed rather rapidly so if the ammonia is still present expect to need lots of initial chlorine before you can even start the shock process to kill anything growing in the water.
    Butterfly's Avatar
    South Carolina
    10,045
    Well, according to the http://www.Poolcalculator.com, 6 pounds of cyranic acid will increase CYA by 36 in your 20K gallon pool.
    You're done SLAMing when:
    Montreal Canada
    326
    Quote Originally Posted by ethany
    We see that all the time up here.
    Butterfly's Avatar
    South Carolina
    10,045
    CYA is sometimes lost over the winter. It is believed that this is caused by anaerobic soil bacteria that can sometimes grow in pool water when the pool is covered and FC levels are zero.
    Be sure to test for CC after shocking.
    Support the site
