Results 1 to 8 of 8
Thread: CYA Life Span
    rgrountree's Avatar
    Nov 2011
    Atascocita, Texas
    13
    CYA Life Span
    What is the expected life span for CYA? How long should it last before I need to add more CYA?
    I have a Taylor test kit and find it hard to read CYA. I filled up the CYA test window before it really became cloudy enough to obscure the black dot. No reading here, but it is less than 30. I have added some CYA about a month ago but it appears my CYA has dropped back down.
    Any advice is appreciated, thanks!
    FC = 2
    TC = 2
    Ph = 7.6
    TA = 80
    CH = 220
    CYA < 30
    23,000 IG plaster pool, Jandy HP Plus 2HP (130 GPM), Jandy CV460 Cartridge filter, Polaris 280, Jandy LXi 400,000 BTU Heater, Jandy Watercolors LED lighting, 7' Raised SPA
    38,524
    Re: CYA Life Span
    Generally the CYA does not get "consumed" and is only removed from the pool due to splash out / backwashing water replacement. There are some reports of the CYA disappearing over winter in a closed pool, but that does not sound like the case here.
    How high was the CYA previously? Note that the test is only good to about +/-10ppm and lighting conditions can affect the test results. More info on the test can be found here: extended-test-kit-directions-t25081.html#p206397
    Re: CYA Life Span
    CYA does occasionally vanish over the winter.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: CYA Life Span
    CYA stays in the water and it is only removed by draining or splash-out. It is very slow to dissolve and can take a week to show up on tests. The only time I have heard of it dropping is over the winter when the pool is closed. Be very careful not to add too much or you will be draining water to get rid of it. Use the Pool Calculator to determine how much to add based on your current level and pool capacity. Proceed with caution!
    Wow, you guys are fast!
    chiefwej
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: CYA Life Span
    CYA does get consumed even in a well balanced pool, but is a very slow process, loss due to back washing, splash out, and rain dilution are likely far larger factors in lowering CYA for most pools. I notice it only because I have an indoor pool where there is no rain dilution and maintain chlorine balance even in the off months when the water is too cold to swim, in general I will see around a 10 ppm CYA loss over the winter non swim season (this has been fairly consistent every year for the last 3-4 years that I have been closely tracking CYA) .
    rgrountree's Avatar
    Nov 2011
    Atascocita, Texas
    13
    Re: CYA Life Span
    Thanks for each of your fast replies!
    22,553
    Re: CYA Life Span
    Do you have an auto fill that may be masking a leak. A leak will dilute the CYA as you're actually leaking it out of the pool.
    Also check the CYA container. There was some posts about 50% CYA. So unless you tested it after ouy added it may not have added as much as you think it did.
    May 2008
    NE Florida
    51
    Re: CYA Life Span
    My CYA goes somewhere every winter in Fl. I usually finish the season at about 40-50. In winter I circulate the pool and don't do much but keep the Cl and pH balanced. The becomes a mess in tree season from Feb-April, then I go crazy to get ready for spring. My CYA is consistantly "0" after winter. So in certain pools it gets consumed or deteriorates somehow.
    22K gallon free form pebble tec pool, non screened, surrounded by 3, 100+ year old Live Oaks (pure misery for 3 months every spring) elevated non heated spa, jandy cl340 filter, Pentair Inteliflo 3hp pump, Jandy 1400 swg, infloor cleaning system which has had all outlets removed due to uselessness of system with the organic load the pool carries and now low rp
