Results 1 to 7 of 7
Thread: New Hayward sp2607X10 pump 115v vs 220V
    norbie's Avatar
    Aug 2007
    Massachusetts
    39
    I just purchased a new Hayward sp2607X10 1 HP pump. It said it came preconfigured as 230V service. I want to reconfigure it to 115V however when I opened up the pump the white arrow on the black connector block (which has the black wire on one side and the white wire with a black line down it on the other side.) was lined up with the 115V arrow. How can I verify I have the connector in the right location for 115V service?
    Thank you in advance.
    Norbert
    23,000 Gallons; 16 X 32 w/ 4 X 8 Steps; Vinyl Liner; Hayward EC65A DE Filter; Hayward 2607X10 1 HP Pump; Hayward CL200 In-Line Chlorinator;
    Bromine; LOOP-LOC Winter Mesh Safety Cover; Aquabot Supreme Automatic Robotic Cleaner;
    Re: New Hayward sp2607X10 pump 115v vs 220V
    Perhaps if you post a photo we can double check it for you.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I would also say post a photo, hayward (or AO Smith who makes the motors for Hayward) has a habit of changing the way the voltage selector looks every few years, I know every time I have replaced my pump or motor the new one was slightly different than the old one anyway.
    norbie's Avatar
    Aug 2007
    Massachusetts
    39
    Here is a picture. Hope it helps.
    Norbert
    norbie's Avatar
    Aug 2007
    Massachusetts
    39
    Also, if someone could take a peek @ this photo it would be great is there any special break in process to follow on a new pump?
    Thank you
    Norbert
    There isn't any special break in procedure, just start using the pump.
    That certainly looks like it is setup correctly for 110 volts.
    norbie's Avatar
    Aug 2007
    Massachusetts
    39
    Than you very much
    Norbert
