Results 1 to 9 of 9
Thread: Cloudy Water still
    Cloudy Water still
    Split off of this topic. Please ask questions in your own topic. JasonLion
    I have the same issue. Only exception is i have a cartridge filter instead of sand. I backed washed a few times last week and changed the filter. Should I use a clarifier? Or let the filter run until the pool becomes clear?
    16k vinyl liner cartridge filter
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Cloudy Water still
    Quote Originally Posted by solobro
    Clarifiers have mixed reviews here. I'll answer your question with a question....How much money do you want to spend?
    Could you post a complete set of water test results and also describe how the water looks?
    As little as possible....but all suggestions are welcomed.
    Smykowski's Avatar
    Sep 2011
    3,065
    Sorry, didn't realize we had a new poster. In general, you don't need clarifiers. However, I'll echo Jason....what kind of test results do you have?
    FC-4ppm
    CYA-60ppm
    TA-70ppm
    pH-7.6
    CH-140ppm
    Phosphates-0
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,008
    FC-4ppm
    CYA-60ppm
    TA-70ppm
    pH-7.6
    CH-140ppm
    Phosphates-0
    Aha!! We have a clue!
    [attachment=0:2vksogmq]pink-panther clou.jpg[/attachment:2vksogmq]
    FC is too low for that CYA level. It should never get below 5. pool-school/shocking_your_pool will guide through what to do.
    Thanks for the tip.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,092
    Also, if the water is cloudy, odds say you have algae. I would bring it up to shock level.
