Results 1 to 9 of 9
Thread: Should I use Metal free?
    Jun 2010
    Dayton, Ohio
    241
    I have iron deposits on bottom of pool. That create a red cloud if agitated. The pool store said metal free will take care of it. I am afraid to trust the pool store. Here are the numbers they gave me. Oh and I added 4 pounds of conditioner yesterday because I tested cya and it was 0.
    TC 9.7
    FC 9.7
    pH 8.3
    TA 165
    Iron .3
    What should I do?
    AGP: 24' x 52" cartridge filter: 13,500 gallons. Taylor K-2006 test kit.
    22,542
    Re: Should I use Metal free?
    The first thing you should do is get the pH down to the low 7's.
    Metal Free isn't one of the suggested one's but a lot of people use it.
    Jun 2010
    Dayton, Ohio
    241
    Can I Lower ph and also add metal free at the same time?
    22,542
    One right behind the other is fine. I wouldn't literally pour them in at the same time.
    ProTeam's Metal Magic and Jack's Magic the Pink Stuff (regular), the Blue Stuff (fresh plaster), and the Purple Stuff (SWG) are some of the top sequestrants. You can also find many other brands with similar active ingredients, some of which are noticeably less expensive. Sequestrants based on HEDP, phosphonic acid, or phosphonic acid derivatives are the most effective. Metal Free is not in this group and is noticeably less effective. It does work, just not nearly as well.
    Jul 2011
    St. Paul, MN
    244
    Is it possible to vacuum-to-waste the area with the iron deposits? You could agitae the area with the vacuum, and hopefully it would suck up the "red cloud".
    20'x40' Oval 27,000 gallon Vinyl IG, Coverstar Auto Cover
    Hayward MaxFlo SP2303VSP, Sta-Rite PLD50 30 sq. ft. DE filter
    Rheem 266,000 btu natural gas heater
    Dolphin Nautilus Plus with Clever Clean
    TF-100 testkit w/ Speed Stir
    Jun 2010
    Dayton, Ohio
    241
    I poured the metal free into the pool and agitated the clouds. My pool looks terrible. When it settles back down I will try to vacuum. I don't think I can vacuum to waste. I usually take out the plug in the filter casing and let the water run into e yard when I vacuum nasty stuff. Should I be doing something else?
    That sounds like a fairly good approach.
    Jun 2010
    Dayton, Ohio
    241
    Thank you. Pool would look great if it wasn't for the iron.
