Thread: cya zero
    May 2009
    Trenton NJ
    497
    cya zero
    I just opened my pool. It looks like shrek's swamp. I test cya and it is zero or so low it is not showing up on test. What would be my shock when its this low? The lowest number on cya/chlorine chart is 60
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: cya zero
    Treat it like you don't have a SWCG for now until you can get some CYA in there.
    May 2009
    Trenton NJ
    497
    Re: cya zero
    how much bleach should I shock/add? Sorry but a little rusty at this and I am trying to do 50 things at once with the day off. Thanks
    Aug 2010
    Dallas, TX
    4,052
    Re: cya zero
    Follow "How to Shock Your Pool" pool-school/shocking_your_pool and use http://poolcalculator.com to determine what your levels need to be.
    22,542
    Re: cya zero
    Shock level for zero CYA is 10 ppm FC. Don't be surprised if your CYA converted into ammonia and you'll need tons of chlorine to get rid of it.
    May 2009
    Trenton NJ
    497
    Re: cya zero
    ok thanks
