Thread: 90 degree water!
    May 2012
    Gulfport, MS
    59
    90 degree water!
    Is there anyway to cool my pool water down? I've thought about throwing 20lb blocks of ice in there
    30'x54" Round Vogue Simbio AG ~21,000 gallons
    Pentair Sand Dollar SD 60 w/ Pentair Dynamo 1.5 hp Pump
    Vinyl Uni-Bead 25mil Liner
    Perfect Bottom w/cove
    Taylor K-2005 & K-2006 Test Kit
    Aug 2010
    Dallas, TX
    4,052
    Re: 90 degree water!
    Throwing ice in won't do a thing.
    Look into something like this:
    dane-s-how-to-for-a-quick-easy-pool-cooler-t36086.html
    Jul 2010
    IL
    201
    I use a fountain that hook up to my return.. Def cools it down...
    24' AGP Sentinelle 54" , 1hp 2 speed power-flo matrix, New 250K to replace the 150k BTU heater, pool roover Jr. Aqua Trol SWG, Large deck, taylor k-2006, Majestic Stairs with colored LED, COLD BEER
    22,551
    Install solar panels and run them at night.
    90 degree water!
    Mine was at 91, but TS Beryl took care of getting back down to the mid 80s. Normally when it gets too warm, I turn on the pump to let the water circulate overnight.
    Sue
    Current Pool: IG Concrete / 11,000 gal. / Sand filter / Solar heat / Hayward CL200 / Screened / TF Testkit
    Pool owner since 2001. Thanks TFP for helping me convert off Baquacil after six years!
    Yep, all the rain and clouds from Beryl dropped our pool temp from 89 to 83.
