Thread: Boric Acid in Canada
    Last year I used Borax + MA for borates.
    I need to raise my borate level, does anyone know where to buy boric acid in Canada
    76549 Liters -- Cartridge Filter -- In Ground -- Vinyl -- TF-100 Test Kit -- AquaVac Robotic Cleaner -- UV Sanitation -- Winter Safety Cover -- Installed 2010 -- Southwestern Ontario, Canada
    Latest Test Results June 25:
    FC - 6, CC - 0, CYA - 40, CH - 110, TA - 90, pH - 7.5
    Montreal Canada
    326
    Re: Boric Acid in Canada
    Walmart used to stock borax - didn't see it the last time I looked.
    Brentag Canada
    Quadra Chemicals
    Kemira Water Solutions
    You may find that using BioGuard Optimizer in the 8 kg size comes out cheaper than the borax/acid combo, and it's much less of a hassle.
