Thread: sand filter?
    May 2009
    Trenton NJ
    497
    sand filter?
    For some reason the glass vial (for lack of another term right now) is empty when in filter mode. I can't see any water pass through. Any ideas?
    Thanks
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    Aug 2010
    Dallas, TX
    4,052
    Re: sand filter?
    There should be a pressure release knob you can open. Just open it until water shoots out and you are good. If it keeps going back that way, you probably have an air leak around your pump basket lid.
    Dec 2009
    Central Massachusetts
    2,690
    Re: sand filter?
    You mean the little site glass on the back of the multiport valve?
    If thats what you mean, its not supposed to have water in it when in filter mode. It only has water in it when the multiport is in backwash or rinse.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    May 2009
    Trenton NJ
    497
    Re: sand filter?
    Sorry,just opened pool. Year goes by and you forget how to operate the filter. Brain fart!
