Thread: Whisperflow vs Intelliflow port dimensions
    May 2012
    Newark, DE
    31
    Hi - I'm considering replacing my 10 yo Whisperflo with an Intelliflo, but wanted to know if the inlet / outlet ports line up EXACTLY - there are 2" unions on each side of the whisperflo (top / back ports), but the height dimensions of the whisperflo and intelliflo look like they are about 1/4" off from the engineering drawings, (and the intelliflo doesn't have any of the port dimesions in their engineering diagrams - only the overall size of the unit.)
    They look the same from the pictures, but would rather hear from somone who has done the swap.
    whisperflo
    http://www.pentairpool.com/images/produ ... lo_dim.gif
    intelliflo
    http://www.pentairpool.com/images/produ ... loBack.gif
    Thanks in advance.
    --Adrian
    22,539
    Re: Whisperflow vs Intelliflow port dimensions
    I haven't personally done the swap but yes, they use the same casing so the ports are in exactly the same location.
    May 2011
    Orange County, CA
    696
    I have done the swap, and yes, the ports are nearly the same (close enough for work with PVC). I ended up adding unions which were not present on the WhisperFlo when I swapped them out. But, if it had unions on before, I could have literally done the replumbing in about 5 minutes. As it was, it took about 15 minutes to redo some plumbing and add the unions.
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
    May 2012
    Newark, DE
    31
    thanks a bunch for the info - I have beer (I mean pump) muscles now.
    --Adrian
    May 2012
    Newark, DE
    31
    Did the swap last Saturday - no major problems - the only thing that I ran across was the electrical 90 degree elbow from the whisperflow didn't fit into the exact same hole onthe intelliflo - had to go buy a straight thru electrical conduit adapter to screw into the intelliflow housing.) (The 90 degree couldn't clear the motor when trying to twist it into the spot where the conduit mounts to the pump motor.)
    It's incredible how quiet the pump is.
    --Adrian
    Sep 2007
    Central NJ
    59
    Makes you wonder what rocket scientist put the conduit connector where its impossible (or almost impossible) to use a 90 degree connector due to the pump fan housing.
    I removed the 3 screws on the fan housing and was able to use a 90-degree connector -- but i had to spin the fan by hand so that the conduit connector would 'mesh' with the vanes on the fan. Problem solved & it saved a trip to get a straight-thru electrical connector. A straight-thru connector would've been a last resort, since the power whip would've been elongated at the back-end of the pump.
