Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: The Green Monster is back!
    Apr 2009
    Raleigh, NC
    120
    Hi All,
    The season has begun...pool looked amazing two days ago and levels were good. Had some metal stains all around bottom and edge of pool. Got absorbic acid and metal out with the result of a sparkling looking liner and water.
    Heater was on and pool was at 85 degrees. Added CoverFree (I wanted to know if it works to keep more of the heat in).
    Also have the metal catcher pouch in one skimmer (forgot what it is called)
    Waited 24 hours, checked levels, Chlorine had dropped to below 1 and ph was at 7.2. Turned on super chlorinator. Next day pool is green.
    Now, I am a bit clue less as to why the pool turned green. Levels today
    FC way above 8. (drop test, stopped after adding 15 drops)
    Could not test for TC because of high levels
    PH 7.5
    Salt is at 2800 ppm
    Alkalinity 60
    CAY (unable to test because I'm out of chems for that)
    Any suggestions?
    Thanks in advance for your help,
    Cheerio, NC Salt
    NCSalt! IG - Mountain Lake 21x40/Vinyl Liner Fiberglass stairs/Hayward Sand Filter/Polaris 3900 w/Booster-pump (5060)/SWG Aqua Rite-Prologic-T-15 cell/Hayward Elec. Heat Pump/2 skimmers/Gallons: 18900/900 sq ft stamped concrete/Concrete Coping/TF100-Test Kit Hot tub: Dynasty Spa/Neptune Series, 5-person, 400 gallons, carbon filter plus 2 regular filters, LED color lights. "I control my pool, and not the other way around":-)
    Aug 2010
    Dallas, TX
    4,052
    Re: The Green Monster is back!
    Do you think it's metals or algae? Can you post a picture of the water?
    Apr 2009
    Raleigh, NC
    120
    Good question, I'm not sure. Will post a picture in a few minutes.
    Apr 2009
    Raleigh, NC
    120
    picture attached
    22,542
    That's metals. You need to add more sequestrant. Raising the FC level brought the metals out of suspension.
    Add more sequestrant until the pool goes clear again.
    Apr 2009
    Raleigh, NC
    120
    THANKS
    Should I add absorbic acid first, than the metal out, or only the metal out?
    22,542
    Unless the stains have redeposited, just add the sequestrant.
    Apr 2009
    Raleigh, NC
    120
    Nope, so far just the discoloration of the water. I will go ahead some sequestrant and will keep you posted! Thanks again
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    That's metals.
    Dave,
    Can you help a newbie understand how you can tell that by looking at that picture? The old aquarist in me would have sworn that was algae, so clearly I'm lacking some knowledge.
    Can you fill in the gap(s) for me?
    -Gordon
    Pool School helps me maintain my 13,500G 24' x 48" ASP with Sand Filtration using a TF100 Test Kit and Pool Calculator.
    Remember, the Shock Process should be followed until : 1. CC is less than 0.5 ppm, 2. An OCLT shows a loss of 1.0 ppm or less and, 3. The water is crystal clear.
    --I didn't buy my pool to swim in it. I bought my pool to watch my wife swim in it. :wink:
    Aug 2010
    Dallas, TX
    4,052
    It is the bright green color and the clarity of the water (it appears clear to me from what I can tell). It's a dead giveaway. That's why I asked for a pic. It didn't hurt that he mentioned he'd had metals issues before, either. Algae is darker and makes the water murky.
    22,542
    If you can see the bottom of the pool and there's a history, it's surely metals. However, I would have guessed metals after reading the first post without the picture.
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    Ok, I see what you're talking about...I can see some of the design on the bottom now that you mention it.
    That's good info, guys! Thanks!
    -Gordon
    Apr 2009
    Raleigh, NC
    120
    Hey Gang:
    I had added the sequestrant and voila the pool became sparkling blue again. But. oops wait...I woke up this morning with a green pool again
    Well, so I dragged my behind to the pool supply store in order to get my water tested (out of CYA stuff so I could not test that myself, big mistake to run out of that)
    Here are the results:
    FC: 0
    TC: 0
    ph: 7.8
    Alkalinity: 80
    CYA: 0
    Calcium 40
    Salt: 3000
    OK....I've decided not to do quick fix "metal free" again but to go with the more "got to have patience" route.
    Pool filter is running -
    AquaRite Salt Chlorinator off.
    Step one:
    Added 38 pounds of "Hardness Plus" - going to wait until about tomorrow afternoon to continue on to step two.
    Step two:
    Add Algae Control (since I am not going to raise the Chlorine at this point) - wait for 24 hours
    Step three:
    Slowly raise Chlorine, not super-chlorination - than add Water Conditioner
    Step four:
    Hope for the best
    I appreciate any input in case you guy's think I am making a mistake or going about this the wrong way.
    Cheerio,
    NCSalt
    Apr 2009
    Raleigh, NC
    120
    Quote Originally Posted by RobbieH
    ... he mentioned he'd had metals issues before.
    HE is a SHE...
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Quote Originally Posted by NCSalt
    HE is a SHE...
    Try not to sound like you know anything about machinery or much other than poppin out pups and cooking. They used to think I was a dude too.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Apr 2009
    Raleigh, NC
    120
    Quote Originally Posted by frogabog
    HE is a SHE...
    Thanks for the laugh
    Apr 2009
    Raleigh, NC
    120
    Rainy Days!
    Hi TFP Friends:
    I am asking my self if this rain is ever going to stop and what it is doing to do to my attempt of getting rid of the metals that have taken over our pool.
    Had metal stains, got them out with absorbic acid, added metal free and voila....stain free and pretty blue...two days later, green! Added metal free again, next day, voila sparkling pool...woke up today...arghhhhhhhhh green again! see my post under green monster for details!
    Just tested again (east coast 9:30 pm):
    FC: 0
    TC: 0
    PH: 7.8
    Calcium: 220
    CYA: 0
    Alk: 80
    Salt: 3000
    Temp: 82 F
    I am just curious of what the heavy rains may do to our pool's metal content. I am apparently having a hard time getting rid of the metals. Has anyone had a similar metal problem?
    NC Salt
    The rain will reduce the metal level slightly, which is good. It will probably also drive the PH up a little, which is bad, but hopefully not by too much.
    You should use a better quality sequestrant. ProTeam's Metal Magic and Jack's Magic the Pink Stuff (regular), the Blue Stuff (fresh plaster), and the Purple Stuff (SWG) are some of the top sequestrants. You can also find many other brands with similar ingredients, some of which are noticeably less expensive. Sequestrants based on HEDP, phosphonic acid, or phosphonic acid derivatives are the most effective.
    You will also have far less trouble with green water if your raise your CYA level to normal levels.
    Apr 2009
    Raleigh, NC
    120
    Thanks Jason, and thanks for moving the post. Raising the CYA is step three on my list. Since I raised the calcium levels the pool is slightly less green. I'm going to leave chlorine at 0 for now until all the green has disappeared. At that point I will raise it and raise the CYA.
    It's a time thingy and I am being very good in not rushing things since the quick fix obviously did not work. I will keep you all posted. Thanks.
  20. Back To Top    #20
    Apr 2009
    Raleigh, NC
    120
    Hi All!!!
    It's been over a week and the pool was clear and blue until this morning. I held of on adding chlorine until last night. And voila this morning the pool had a slight green tint.
    Let's recap:
    Metal drama a few weeks back
    Quick fix - worked temporary
    Decided to actually work the problem out
    Raised Calcium - check
    Raised CYA - check (still needs more raising)
    Added Alge preventer
    Anyhow -
    Yesterday evening
    I added algea stuff yesterday evening since I saw slight algea growth (of course since there is no CH)
    I brushed the pool and vacuumed (pool was slightly cloudy but blue)
    Set the Aqua rite to super-chlorinate (I figured that I've waited for over a week for the metals to dissipate and I can now safely introduce CH)
    This am:
    Pool turned slightly green
    Backwashed
    Turned Vacuum back on
    Outside temp>74
    Pool temp>81 (heater was on over night)
    Tested chems:
    Ch> 0
    Ph> 7.8
    CYA>20
    Salt>
    Alkalinity>80
    TC>drop test was inconclusive (turned slightly pink and after adding 6 drops I figured it's not worth it to waste chems)
    I am going to check the pool calculator next in order to:
    Lower Ph to 7.4
    Raise CH to 1pmm
    Raise CYA to 40
    Note: I also have the Culator Metal Remover in my skimmer for almost 2 weeks now), it seems to draw the metals out (it's turned color from white to brownish/yellow)
    Any suggestions?
    Thanks, NCSalt!!!!
